14 RB mods & repair
3:04 pm
July 2, 2011
Winterpegger
Winnipeg, Manitoba
posts 18
Bed support under dinette caved in !!   I installed vertical reinforcement boards on each side of the support boxes. Three on each side inside and out.
Bracket for coat hangers came loose so I installed a board above the closet to screw it in more securely. Also found frame with stud finder and installed some small hooks in the closet walls.
Installed a 12″ x 48″ mirror on out side of bathroom door.(screwed and taped).
Hung a shoe holder on inside of bathroom door. 20 pockets for lots of stuff.
Pictures to follow.
9:35 pm
July 7, 2011
Welcome to those continuing good ideas.
7:42 am
July 24, 2011
Niagara Falls, Ontario
posts 114
Winterpegger …
Bearing in mind that I am all thumbs … what did you screw the mirror into? Are there studs in the bathroom door or what? Also … what kind of "tape?"
I found a nice paper towel holder but am not sure if I should screw it into the wall above the stove area. (outside wall which seems sturdier probably because of insulation or the wall adjoining the bathroom which his really thin) The walls seem rather flimsy to me. Would I use "tape" for that??
Also … pictures are always nice.
8:53 am
July 24, 2011
kayaknut
posts 376
Post edited 1:56 am – January 14, 2012 by kayaknut
2:27 pm
July 24, 2011
I mounted a towel ring onto my bathroom door with 2 screws.  The door holds the screws just fine.
2:12 pm
July 19, 2012
Winterpegger
Winnipeg, Manitoba
posts 18
Post edited 3:47 am – July 23, 2012 by Winterpegger
