My wife and I are wondering about a more comfortably bed for our dining table than that mystery foam that came with it ( it's a mystery where it goes after about an hour of sleep feels like concrete)
We are vertically challenged ie: heavy set people..
I would suggest replacing the existing foam with higher density pieces, cut the same size, remove the covers and switch. Otherwise, you can purchase a seperate memory foam-type topper that can be rolled up and stored in the overhead compartment (or the top bunk if you don't use it) or perhaps even stuffed into a storage bin that can go under the table at the back end when not in use.
