8:29 am August 23, 2010
| homebodyfl
| | Miami Gardens Fl | |
| Member | posts 20 |
Got my KZ sportman 13fk already took out the 38lb table and replace it with 1 x 3 1/2 slats for the bed. More floor space and only 24 lbs.. I have a question?? Want to replace the chip board storage covers with something lighter but strong enough to hold up my fat butt..Any one know of something I can buy?? Need name and where to purchase…48″ x 24″ need two..
Nancy KZ Sportman Classic 13FK Sorento Skootie & Sherlock
12:26 pm August 23, 2010
Post edited 2:57 am – September 3, 2010 by smilinjohn
Hi, Nancy!
Our 14RK came with 5/32″ to 11/64″ plywood wall paneling as the 24″ x 48″ supports for storage covers. The same stuff used on the 14RK's walls. Perhaps inexpensive (cheap) decor wall paneling from Mennard's Building Supplies or Home Depot (Minnesota) or other lumber yards. Many of them will cut-to-order for you and at no charge.
Additionally, I used 2″ x 2″s, 1″ x 2″s Fir or Pine stock and steel "L-brackets" to beef-up the horizontal 1″ x 2″ factory cross supports of the storage / seats. The 10-gallon fresh water tank / 12 vdc pump is now separated by a plywood insert, so the plumbing would not be inadvertently injured with my 2-ton jack rolling around in the newly created compartment.
3:39 pm September 3, 2010
Hi, Nancy!
Did you replace the chip board storage covers……what material did you use?
1:44 pm September 6, 2010
| homebodyfl
| Member | posts 20 |
Finally got an answer from an Aliner dealer..he said the wood is luann…anyone heard of it.
Know when I had my Aline the storage covers were lsuper light but held up 3 people on each side.
Going to go to Lowes etc this week and see what they say or look at the plywood.
Nancy, Skootie & Sherlock
13FK
11:55 am September 7, 2010
Lauan is a type of wood from the Phillipines. It's rated as a mid grade mahogany. Good wood basically.
