5:51 pm March 26, 2011
I used an angle grinder to shape a 3/8 drive socket to fit on the crank handle then welded it on. A wet rag wraped aound the shaft protected the nylon bushing. I cut slots in a 5/8 deep socket to use on the stabilizers. Like others I could not post a photo directly but it can be seen here. http://thelegoes.shutterfly.com
8:22 pm March 26, 2011
I made my own a few years back. He will be 8 this year & loves to put down the stabilizers & tongue jack.
8:34 pm March 26, 2011
My twins are 4 1/2, they just get in my way.
9:57 pm March 26, 2011
I imagined the original handle being removed, but you welded onto it. So when you turn on your drill, doesn't that long handle zing around really fast? I'm wondering if it could hit you in the knuckles or something.
10:09 pm March 26, 2011
One does need to be careful but the everthing does clear the hand and knuckles. I operate the drill facing the trailer. I wanted to be able to use the crank incase of drill / drill battery failure. I contemplated cutting the handle off and welding a male 3/8 drive onto the cut off crank end and stowing until needed.
10:37 pm March 26, 2011
Clever idea.
