7:57 pm January 15, 2012
| Cat
| | South Florida | |
| Member | posts 27 |
Hello All,
I know to some tires are boring but none the less an extremely important item on your RV. (Or any other vehicle for that matter.) So here is an upgrade I made recently…
Althought the tires were not bad on my 2010 14RB, having taken 2 cross country trips I felt they could be replaced. It was then that I really paid attention to the load range of the factory installed tires. The trailer came w/ load range C radials tires 175/80R13, that allows for 1360lbs. per tire. Or 2720lbs. total. And also has 6 plys. Now, I have weighed my trailer loaded and ready to go at 2500lbs. That seemed too close to the max weight limit. And there's not enough room in the wheel well to put on a 14″ tire. After researching , I found a Kenda Karrier load range D, 8 ply radials online for $62.20 ea. w/ $25 ship. Those tires will increase the max load up to 1610lbs. per tire or 3220lbs. total. (Yippee!) After they were installed, I noticed that the "sagging" appearance was gone too, compared to the other tires. Higher inflation max too at 65PSI.
Here's something else to consider when buying tires, any tire, car, RV or whatever…Tires are imprinted w/ a date code. By law, it is located in an oval mark on the side. It is usually proceeded by the letters DOT and will consist of 4 digits. For ex. DOT 1211, that means these tires were MADE in the 12 week of 2011, or approx. March, 2011. The experts I consulted suggested never putting a tire on that is date coded older then a year. Rubber dry rots etc. When I bought the new tires I called and asked what the date code was on the specific tires they would be shipping.
Hope you weren't too bored! Keep on rollin'…
8:15 pm January 15, 2012
Where did you find your tires? I'm pretty sure that I'm very close to the max right now on mine.
2:04 pm January 16, 2012
| carolandjack
| | Spring Hill, Tennessee | |
| Member | posts 62 |
About 15 months ago, I had the axle flipped on my 16BH. Have been pleased with the decision. Seems to pull just as good and it sits higher to empty tanks, etc. No problem here. Cat, I read with interest your blog on the tires. We are taking a long trip out west next summer and will be replacing our tires probably in June. Your information on the tires was super and I will be upgrading them. Now, I have a question for you or anyone else out there…………..I have 13″ rims/tires now as we all probably do. But, since I have flipped my axle, I have tons of room for 14″rims/tires. What are the pros/cons of making that switch to bigger rims vs. staying with the factory rims.
I am with sandersmr, Where did you get them?
Jack
5:19 pm January 16, 2012
| Cat
| | South Florida | |
| Member | posts 27 |
Post edited 12:20 am – January 17, 2012 by Cat
sandersmr said:Where did you find your tires? I'm pretty sure that I'm very close to the max right now on mine.
I bought the tires at http://www.trailertiresandwheels.com , Just checked and they still have them at that price. LRD Kenda Karrier tires ST175/80R13
Jack,
Other then a slightly higher price for the tires, I was never told anything negative about upsizing the tires/rims to 14″. (I just don't have the room in the wheel well.) In fact just the opposite. 14″ tires come in higher load carrying capacities etc. I would think with your axle flipped the 14″ would give you even more clearance. I'm beginning to wonder if the extra 2 feet length of the 16BH is what makes the rear/front scrape? I hit the road one time going up to a gas station, even at an angle, on a 7000 mi. trip in my 14RB. Even so I know these trailers sit low and there have been driveways, entrances and roadways that I have had to detour because of the low height. Thought about flipping my axle too. It's good to know it still tows good even though it's sitting up higher. Could you please elaborate on your axle flipping project? Parts, cost, suppliers? Did you do it yourself? Thanks, Cat
5:55 am January 17, 2012
| carolandjack
| Member | posts 62 |
I bought the over/under conversion KIT-2.38 (K71-384-00) for $34.10 From:
Dexter Axle
500 S. 7th St.
Albion, In 46701
Phone 260-636-2195
I called KZ @ 1-866-472-5640 to be certain that I order the correct one because the diameter of our axle is most important. We need a kit for 2 2/3″ tube. It is always a good idea to give KZ a call, tell them which unit you have, just to confirm the correct kit to purchase. Your choice is either for the 2 2/8″ tube, (mine) or the larger 3″ tube. I also called Dexter and ordered the conversion kit. They were also very helpful in directing me to the proper kit.
I had a local garage who I use regularly install it. He said it was easy to install and charged me $175.00 to do it. Again, I have heard both the pros and cons on this blog, but if I had it to do over again, I would not hesitate. The unit handles very well when traveling. Also, thanks so much for the info on the tires. They look like they will improve handling and safety!
Jack
2:19 pm February 5, 2012
| Cat
| | South Florida | |
| Member | posts 27 |
Hello Jack, I am seriously considering doing the axle flip on my 14RB and am wondering about the "cons" you mentioned in the last post? I have searched the forum and so far have found only good results from flipping the axle springs to achieve more ground clearance. Any negative effects from having this done? Thx, Cat
9:47 am February 7, 2012
| DougB
| | Charlotte, NC | |
Thanks guys for sharing the information.
I too am concerned about the load range of the stock tires since I have also weighed my TT and found it to be 2550 lbs when loaded. Plus with all the appliances on one side I'm sure that side has more than %50 of the weight. The "sag" is more noticable on that side.
I have the over/under axle conversion kit but haven't had it installed yet. I drag my 16bh every time I pull out of the driveway. I was considering 14″ tires but am not too keen on buying 3 tires and wheels so it's good to know I have the option to upgrade just the tires.
6:57 am January 14, 2016
| wendell
Cat
Or anyone else that use the Kendra karrier 8 ply tires on the 14rb.What do you think of them? Any problems? Would you recomend them?
9:24 am January 14, 2016
| Cat
| | South Florida | |
| Member | posts 27 |
wendell said:
Cat
The Kenda tires I bought, weight capacity was well over rated for my light little camper. They were within the warranty period when one developed an interior bubble in the middle of a cross country trip. Thankfully I noticed the miss-shapen tire before it exploded and had it replaced. The tire was only 1 or 2 years old max. Properly inflated etc.etc. I have since purchased a 2014 KZ trailer, a little bigger, still single axle but it came with 14″ tires. This trailer has been across country twice so far with no problems. Bottom line is I am not convinced that a higher weight capacity tire or even a "good" name brand tire is any guarantee against failures. (I had a Maxxis tire fail,bubble, within the first year on another trailer once.) When I replace my current tires I plan to go with exactly what came on it from the factory. They are an off brand called Freestar, made in China. (It's extremely hard if not impossible to find a trailer tire made in the USA.) I think it's a crap shoot no matter what tire brand you pick and atleast in my experience the Kenda tire still failed even when greatly over rated for my trailer. I still strongly suggest paying attention to the date code and only buy tires that are dated within 6 mos. Hope this helps.
12:51 pm January 17, 2016
| wendell
Thanks cat.
Our 2015 14rb came with freestar tires. Two seasons and over 10 thousand miles with no problems. I think I will go with riser blocks and go with 14″ tires.
1:31 pm January 17, 2016
| Cat
| | South Florida | |
| Member | posts 27 |
wendell said:
Thanks cat.
My experience when I had the axle flipped on my 14rb was great. I think it only cost me about $50 at the trailer shop and the increased clearance was wonderful. I never did change the tire size and ran the 13″ tires on it. No more worrying about bumps, driveways etc. and I did not notice any difference in towing with a higher profile. Nice to hear someone using their camper so much! 10k miles in a year means you are going places…have fun!
