7:50 am June 29, 2011
| Chris Tod
| | Sackville, N.B., Canada | |
| Member | posts 21 |
I am wanting to attach a shelf I've made to the wall to the left of the toilet. Does anyone know how thick the stud is in the centre of this wall? I assume there are studs at the corners Does anyone know how they are configured, with a view to how I might support the shelf at the corners?
2011 Sportsmen Classic 14RB 2010 Ford F150 4.6L V8
10:02 pm July 14, 2011
Chris, perhaps a call to KZ-RV Customer Service might result in someone in Engineering checking the Engineering Drawings for your 14RB. My best guess is 1-3/4″ x 1-3/4″ x 16″ On Center and probably similar stud at the corner. You might find the approx. dimensions by test-drilling with a small drill bit.
1:42 pm July 15, 2011
Their is a drawing on this site somewhere that shows the placement of all the studs. Not sure where or what model but I will look around and see if I can find it.
2:15 pm July 15, 2011
Post edited 1:56 am – January 14, 2012 by kayaknut
11:00 am July 21, 2011
| Chris Tod
| Member | posts 21 |
Thanks everyone. I did find a stud about 16″ from the door corner. Test holes help fine tune its location.
