I bought one of these, and went from 5 UHF channels and 8 VHF Channels to 9 UHF and 8 VHF channels, plus increased signal in the UHF spectrum.
To install, you need to pry the 3 rubber feet off the antenna bottom, then install the antenna using 3 black plastic push insert plugs in the 3 holes that the feet were in. Don't worry, there are new rubber feet installed on the Wingman attachment.
Easy to install, hint for those of us tall folks, turn the antenna 90 degrees and crank down so the bottom of the antenna overhangs the awning at the entry door. Then stand in the doorway and pull the feet, and install the Wingman.
