Greetings Members:
I am the proud new owner of a KZ16 and I have a problem that is driving me crazy. There was no battery included with by trailer, so I currently have an older vehicle battery in there just to get things up and running.
I hooked the battery up with the two available leads, Red & Black then went and checked things in the trailer, no lights, but I did notice there was a red light beside a 20 Amp fuse for the reverse polarity overload. According to the sticker on the panel that should likely be a 30 Amp.
I head over to the store, pick up a few fuses for spares, 15′s 20′s & a 30. I go to install the 20 into the battery overload, but I get a spark immediately. I pulled it away in time that it didn't blow. What the heck is going on I thought. So I go and remove one of the leads off the battery. Install the fuse, hook up the battery lead, only to have a spark on the terminal. Guess what? Blown fuse again. All breakers are turned off as well by the way. I then disconnect the other battery lead this time and install a 30 Amp fuse, hook up the battery lead, blown again.
What is the deal with the battery hookup? I have looked in manual for the trailer and the circuit break with no information on hooking up the battery or how to replace the fuses.
Any comments and/or suggestions would be appreciated.
Avro
