5:35 am May 23, 2011
| Buzz
| | West Palm Beach, FL | |
How do you drain the fresh water tank in the 14RB? I can see the tank and a valve, but when I turn the valve, nothing drains out. There is about 1/2 tank of water and I won't be using the RV for about a month or two. There has to be a way to drain it. Thanks for the help from everyone.
5:48 am May 23, 2011
| DaveandRose
| | Sarnia Ontario Canada | |
| Member | posts 36 |
On mine I have to pull the valve up to allow the fresh water tank to drain. Turning it does nothing just like you said.
Dave
6:45 am May 23, 2011
Post edited 2:06 am – January 14, 2012 by kayaknut
2:19 pm May 25, 2011
When I wanted to drain mine last April I switched the pump on and ran the toilet till the water quit. It helped clean the black tank. I haven't checked to see if that left any water inside the tank. Guess you have me wondering, I might need to go look sometime.
2:36 pm May 25, 2011
When I first filled my fresh water tank the water was "leaking" out. Had no idea what was happening. Then I remembered the valve the dealer showed me during orientation. I turned it to the left and I turned it to the right. Nothing!! Finally I pushed that darn think in and volia!! The water stopped leaking out.
Is there a way of putting a valve on the outside rather than digging into the inside to get at it. I have to move my single mattress to get at it. Although it is doable, it is just a pain.
I will try Mike Magee's method initially, but for the winter here in Canada that won't due. It will have to be winterized … but we'll cross that bridge when we get to it.
