It is that easy. The threads on the tank are left hand, righty loosy lefty tighty. Turn on the valve slowly after the freshly filled tank is re-installed as the tank may shut down. There is a built in device that turns off the flow in the event of a major leak, I learned the hard way with my pop up trailer. The device will reset after a while. You can purge the air out by lighting the cooktop.
