I've got 3 issues that I've noticed over my last 2 trips camping.
1) Rear light kept going out and the lens cap had dirt and the light fixture and bulb had signs of corrosion. Sure enough, it rained a little yesterday morning and I noticed that there was some water in the lens cap. I replaced the bulb and used bulb grease, but why am I getting moisture in the lens cap? The cap is meant to come off, has ears on the 2 sides to remove it. But I'm wondering if it should have some sort of caulk or sealant that can be cut loose when the bulb needs to be changed. I've noticed the other lens cap has dirt in the bottom like it's also had water incursion.
This could be a safety issue since the bulb appears to have prematurely failed due to corrosion. I noticed Friday that people kept trying to cut me off as I was switching lanes to the right – probably because my turn signal went out during my drive.
2) It looks like there's no sealant between the sink and the counter. I made a mess last night washing dishes and noticed this morning there was water under the sink. I'm thinking it came from water getting under the sink rim. Again, silicone caulk should seal that, but shouldn't that have been sealed during production?
3) And the other problem that's really a biggie – my hot water heater won't stay lit. I noticed it happen last trip, then I had to light it 3 times this weekend. Yesterday I could sort of understand because it was really windy as a front blew through. But the wind died down last night and I still had to re-light it this morning when I realized I had no hot water. Any one else have issues? The pilot light appears to be a good shape and blue when lighting it.
