5:16 pm February 26, 2012
| reeljuals
| | Orange Park, FL | |
| Member | posts 43 |
Is there a way to turn down the temp on the water heater? Checked my manual, and it says unit will automatically shut off when water reaches 120 degrees. That makes me think there is no wat to adjust it.
2012 Sportsment Classic 19BH w/U-Shaped Dinette
6:37 pm February 26, 2012
I thought mine had an adjustmet outside, but now I'm trying to remember. It seems like we did turn ours down some because the water was so hot. It's dark outside or I would go out and check.
9:11 pm February 26, 2012
| whitedvr
| | Missouri | |
| Member | posts 38 |
Now granted mine is a propane water heater and I have to set it on low, and I think thats too hot sometimes they are definitly good water heaters.
2005 jeep grand cherokee 4.7 laredo with tow package towing a 2011 sportsman classic 16bh using a wdh and swaybar combo.
7:57 am February 27, 2012
| Mike & Diana
reeljuals said:Is there a way to turn down the temp on the water heater? Checked my manual, and it says unit will automatically shut off when water reaches 120 degrees. That makes me think there is no wat to adjust it.
We can adjust ours on our 2011 19SB. As you look at our hot water heater, just to the right of the "Pilot/on/off" plunger, you'll see a black quarter circle tab with five holes that select temps from low-high. Pull tab and turn to engage desired temp hole We always run on low. More then adequate temp.
Good luck.
10:14 am February 27, 2012
Thanks for posting, Mike. That's what I was trying to remember what we did. We keep ours set pretty low as well.
12:06 pm February 27, 2012
| reeljuals
| | Orange Park, FL | |
| Member | posts 43 |
Appreciate the info – will check for the tab.
5:58 pm February 27, 2012
I think the 'low' setting is still way too hot. I've found that after getting to the campsite, I'll let the heater run for a while then turn it to 'pilot'. There's plenty of hot water for many hours (except showers, of course), and the burner doesn't have be on for as long or as often. Keep in mind the the pilot light itself still adds some heat.
3:22 pm February 28, 2012
While safety around hot water is an important issue, I think the water heater mfr may have chosen to set the heat so high to help with the heater's small capacity. Having the water extra hot lets one mix with more cold water to make a larger quantity of just-right water than what would otherwise be possible.
