highpointday said:
I am trying to decide between the 13FK and the 14RK (if I can find one). I'm ondering if the 13' sways too much? Is the RK a good idea for weight distribution since I am towing with a '93 Lincoln Town Car? Someone told me I should carry most of the weight on the back of the trailer, not on the hitch because of towing with an auto..even though it is a tank. Any input would be appreciated.
I might add, the 14RK, from the floorplan looks like it has a lot of counter space. But the 13' sure looks "cute."
Thank you!
Welcome, 'highpoint' to our small corner of the globe.
I'd check with the expert at e-trailer.com, Bob Gisi @ (636) 887-9346 (direct)…..hitches, sway control, Lincoln Town Car towing capacity, etc. I'm guessing that Bob has had some Mechanical Engineering background. Bob has helped me put together a very safe towing package. Also, speak to your local tech person at your Lincoln dealer and see your owner's manual for towing capacity…..perhaps, Lincoln dealer has stiffer/heavy duty rear springs/shock absorber available. A transmission cooler is highhly suggested, also. A good rule of thumb to follow to control sway……for ever pound of weight placed behind the axle, place two pounds in front of the axle…….thus, 167 lbs. behind axle / 333 lbs. in front = 500 lbs. of camping stuff in the TT (travel trailer), to maintain the needed 10-15% of trailer weight for the tonge weight.
Prior to purchasing our 14RK, I fantisized about sitting in the rear of 13FK, while trying to watch LCD/HD TV on the front counter, concluding too difficult with refrigerator cabinet blocking / limiting the view.
13FK has about 54-56″ counter space, with lower cabinet space, + top of refrig. cabinet. My fantasy made the 13FK just too claustraphobic, for my liking.
I measured counter spaces in our 14RK to help you and others decide. Thus, refrigerator cabinet top = 4' high x 25″ wide x 23″ deep. The right angled, right side-rear countertop measures 52″ frig. to rear-corner, 56-1/2″ rear-corner to outside bathroom wall…….22-1/2″ deep. The front right-angle (counter leading edge) measures 30″ x 34″. The stainless sink measures 13″ wide and is 17-1/2″ from bathroom wall. The outside corner to inside corner of the right-angled countertop = 32″ diagonal.
Keep the questions flowing.
