8:14 pm September 4, 2012
Post edited 3:19 am – September 5, 2012 by Mike M
Hey All,
Did my first real dry camping trip with the Classic 190 a few weeks ago. One of my hobbies is astronomy, and I recently attended the Stellafane convention in Springfield, VT. http://stellafane.org/conventi…..index.html I wasn't sure how long any of the support systems would last, so I had extra everything. Turns out I was significantly over-prepared. I filled the propane bottle before I left, and after 4 days of fridge and hot water it was probably still 2/3 full. I brought 38 gallons of water (20 in the tank and three 6 gallon jugs) and wound up jettisoning two of the jugs contents before the ride home. This was after cooking all my meals for three days and two showers. Finally, the battery held up fine, still showing 12.2v at the end of the trip.
In addition to the extra water I brought a spare propane bottle and a spare battery. I now know that I didn't have to do that. It should be noted that electrical power usage was very judicious. The only real consumption was to run the water pump on-demand. At astronomy events, the use of white lights is strongly discouraged, if not outright enforced by threat of violence. Thus, it is prudent to red-light your coach. This is achieved by replacing a couple of the standard #921 bulbs in the coach lights with specialty red LED bulbs. Although a bit pricey at $12.00 a pair, these little gems draw next to nothing for amperage and could potentialy last a lifetime.
Here's my trailer and tow vehicle in the field:
An image I made on one of the nights there:
Mike M.
9:15 pm September 4, 2012
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
Cool photo of the cosmos whirling about your campsite, Mike. How long was the exposure?
I also over-prepared for my first dry camping weekend, though not quite as robustly as you did. Similar results, though: Used less of everything than I expected, particularly propane and battery juice. I've replaced all my 14RB incandescent bulbs with warm white LEDs and man, does that make a difference to the little Interstate Group 24 battery. I've been toying with the idea of upgrading to a Group 27, but I can't kill this HD-24DP. What kind of battery do you have, Mike?
Thanks for taking the time to post. I appreciated the urging to reinvigorate this forum and promised I would let people know I'm reading their contributions. I'll make some more of my own after I figure out how to post images without using the Tiny Browser approach, which has stopped working for me.
Peace.
10:13 am September 5, 2012
Where can I purchase those warm white LED lights and what is the model number? I would like to replace all of mine in my 14RK. Thanks
12:59 pm September 5, 2012
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
Teaspoon:
I got mine on eBay for $3 each. You need eight for the interior lights of a 14RB. The technical details are below. The bulb is designated T10 194 921 W5W Bulb Lamp 24-1210SMD LED,Warm White 12V. It is a flat circular disk with 24 LEDs, close to the same illumination as the incandescent bulbs it replaced, perhaps a bit dimmer. Light disperses at a 120-degree angle but mostly downward, which is exactly what you want in the ceiling and under-cabinet fixtures. The most impressive thing about these $3 bulbs is the warmth of the light. It is not the cold bluish freezer light of old school LEDs. You can hardly tell the difference from the incandescents. Except there's no heat and they draw a tenth of the power from the battery. The fit of the LED T10 blade base is a bit tight in the fixture, so I had to be careful putting them in (I used a little WD40), but it was not a big deal. Makes a gigantic difference in power consumption and almost no difference in level of illumination or warmth of light. Highly recommended, inexpensive and easy mod.
I believe the outside porch light is a bayonet-mount 1156 BA15 base, and I got an LED replacement on eBay for $5.
technical details for the interior lights
Base: T10/921/194
Input: DC 12V(No positive and negative)
Power:0.85W
Light plate diameter:26mm
angle: 120°
color: Warm White (3000~3500k)
Life time: more than 50,000 hours
1:31 pm September 5, 2012
Peace.
Thanks, Jim. The photo is a 1.5hrs composite of 30 seperate three minute exposures. The camera is a Nikon D5000, the lens was a Sigma 12-24 set @ 15mm, and the ISO was @ 800.
My unit came with an AC Delco battery, I'm not sure exactly what model. I have added a set of leads to be able to hook up another battery in tandem for longer off-the-grid stints. Pictures to follow.
The tiny browser works for me, but it's certainly not the most intuitive thing I've ever used. Really, it's a little clunky is the best way to describe it, but I've found it to work better if I make sure my pictures are downsized to a maximum of 800×600.
6:12 pm September 5, 2012
Thankyou so so much Eugene
4:27 pm September 12, 2012
Heading out again this weekend. Just two nights, less than a hundred miles away. Won't be bringing nearly as much this time. May need the heat though. Been skimming the upper thirties around here the past two nights.
3:24 pm September 13, 2012
Mike – what size batteries are you running? I'm going to upgrade mine from a Group 24 to a Group 27 Deep Cycle and may go with a second one depending on usage. We will have a generator for those trips where it's called for.
11:18 am September 16, 2012
My unit came with an AC Delco series 24 deep cycle battery. So far it's been pretty good. 4 days dry camping and still had plenty left. Just got back this morning from a couple of nights dry camping down in Connecticut. Again, all was well. Had to run the heat last night as the temps were in the upper thirties when I crawled in at about 2:00am. I thought about clipping on the extra battery, but didn't bother.
6:15 am September 17, 2012
| Mike & Diana
If you worry about the battery getting low / see dimming lights…., you could hook up to the TV, run for a hour, and charge it up. Just don't stay hooked up, you'll drain the TV battery.
12:32 pm September 17, 2012
| Suzy-Q
| Member | posts 54 |
Sue and I are big dry campers and rely on solar for refrigeration. We have solar panels on the 14RK and the Van. We did a 56day trip and had shore power four times.
HTH;
2:01 pm September 17, 2012
Mike & Diana said:If you worry about the battery getting low / see dimming lights…., you could hook up to the TV, run for a hour, and charge it up. Just don't stay hooked up, you'll drain the TV battery.
At first I was like "TV?, this dude is losing it", then I figured out your unorthodox acronym use. My vehicle actually doesn't charge the battery as I drive. It can if I want it to, but I have to install the relay and fuse for it to happen. I think they sell it like that to prevent bonehead things like draining the battery from happening. They probably figure if you know enough to put the parts in to make it happen, you know enough to pull the cord before using it up.
Mike M.
2:07 pm September 17, 2012
HTH;
56 Days…that's an awesome stretch mostly off the grid! I'm just wondering, you said you're using solar for refrigeration? Does your fridge operate on 12v? Mine is only 120AC and propane. I've found it to use miniscule amounts of propane. I like having shore power though…microwave, toaster oven, coffee maker, electric heat, AC, TV (as in watch the news, not pull the trailer ). With shore power I only need propane for hot water and the stove.
Mike M.
2:49 pm September 17, 2012
| Mike & Diana
Post edited 12:59 am – September 18, 2012 by Mike & Diana
Mike M.
Actually, the acronym "TV" for tow vehicle, has be used on this site for a few years. That's where I picked it up, of course! Similiar to "TT" for Travel Trailer.
If your trailer came with a 7 pin connector, as mine did, then the TV can be fitted with a battery isolator that sends current from the alternator to both the TV & TT batteries simultaneously. See your owners manual under 12 – volt DC system…Converter…Circuit Breaker and Fuses – 12 Volt DC.
6:27 pm September 17, 2012
| Suzy-Q
| Member | posts 54 |
Post edited 1:29 am – September 18, 2012 by Suzy-Q
Hi Mike;
Our 14RK is the all electric model, no propane. It came with a dorm fridge which we removed and use the space for a microwave and stow bedding below.
We have two Dometic CF-35 12V compressor fridges that we carry in the van. One for fridge, the other for freezer. They are powered by an aux battery and 170W solar that is mounted on the roof rack.
In addition to the microwave, we cook with an electric hotplate and a coffee maker powered by a 2KW inverter-genny. A 130W solar on the roof runs the LED lighting, the television(12V) and pump and charges the TT battery. We also cook outside with a portable propane stove. I moved the battery from the tongue and to under the dinette seat so that it is next to the converter/charger. We use the tongue area to carry the genny.
We run our laptops with 100W pocket inverters.
We like to keep the 7-pin connected whenever possible so all three batteries can share loads and share the solar charging. We have never had the starting battery run down. All three batteries are AGM. The alternator also charges all three AGMs.
HTH;
6:15 am September 18, 2012
| Mike & Diana
Boy. I'd say you guys are really, "Off-The-Grid".
Pretty innovative.
I'm sure others, as I learned something.
Thanx
8:49 am September 18, 2012
| Suzy-Q
| Member | posts 54 |
Pretty innovative.
Thanx
31 consecutive days off-grid is our max.
1:46 pm September 18, 2012
Suzy Q, that's quite the system you have there. I'm still glad I've got propane to work with, but I'm very interested in your solar panels. Would you be amenable to sharing the brand and cost of those units you're using?
Thanks,
3:55 pm September 18, 2012
| Suzy-Q
| Member | posts 54 |
Thanks,
No problem sharing info. However, panel brands are meaningless as there is constant turnover, plus costs have dropped dramatically. You need to know how to size the system for dry camping and then shop for the parts. Is that what you want to do?
Anyway, panels cost about $1 per watt and under $200 will provide a DIY solution for someone in your position.
HTH;
1:46 pm September 19, 2012
HTH;
Yes, I would like to establish a means of extending battery life for dry camping trips. a couple of hundred watts would likely meet my needs for the times I do it. Thanks in advance for any assistance you have to offer.
