5:37 pm May 10, 2012
| eocamper
| Member | posts 19 |
Post edited 12:41 am – May 11, 2012 by eocamper
I have a 2012 19SB that i've had a month. The battery was fully charged last weekend. Today I went in to stock a few things for our up comming trip and the lights would not come on. Coould someone tell me what is draining my battery?
8:14 pm May 10, 2012
Perhaps, a good question for your dealer. Dealer probably has the test equipment to pinpoint the problem.
8:01 am May 11, 2012
your carbon monoxide dectector was going off was it? that happened to me once while my trailer was stored for winter…I walked by it the next day after storing it and heard a beep beep beep comming from the trailer…had to hit the reset button. If i didnt happen to walk by I imagine it would have drained my battery. I have no idea why the alarm was going off.Now when park my trailer for storage I disconnect my battery to be safe.
9:35 am May 11, 2012
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
I've experienced unexpected rapid battery drain twice, essentially overnight or within 36-48 hours of having the battery appear (by the brightness of lights) to be well charged. I have a 5W solar trickle charger connected to the battery, and so my first thought was that the rather cheap-looking controller was malfunctioning and draining the battery at night. That's still one possibility. I beefed up the wiring and made the connections as clean and tight as I could get them and it hasn't happened again. But I'm not convinced yet that it's the solar controller. When I picked up my trailer (a 2011 14RB), it had a blown 20A fuse in the circuit that comes from the 12-volt battery side. Never be too quick to accept the easy explanation for electrical problems.
11:32 am May 11, 2012
| eocamper
| Member | posts 19 |
Thanks for the replies. I'm pretty sure it the gas leak detector. Looking into a cut-off switch for the battery.
12:46 pm May 11, 2012
| bojewy
| Member | posts 27 |
By chance, do you have your fridge on the 12VDC option?
7:00 pm May 11, 2012
eocamper said:Thanks for the replies. I'm pretty sure it the gas leak detector. Looking into a cut-off switch for the battery.
although i am sceptical that the CO detector could drain a battery in a week under the right conditions i guess its possible. As eugene alluded to, electrical problems are not always easy to pinpoint. he also mentioned the 20 amp (yellow) fuse in the converter. if you pull that fuse, i believe you essentially disconnected the battery from the system (a cheap noninvasive disconnect ) just remember to put it back though before taking off. it looks like that fuse protects the only connection to the battery, and if thats so, the break away brakes would not work under an emergency situation.
when this fuse blows (as folks can attest) nothing works inside unless you are plugged into shore power. (connected, you are generating the required 12v in the converter. however you are not charging the battery because the same path to the battery from the converter is used for charging so its lights out when you unplug.)
1:55 pm May 12, 2012
| mcmanawayp
| | Richland Center, WI | |
| Member | posts 37 |
You might also want to double check that the antenna signal amplifier is shut off. It's really easy to forget that thing and it can take a toll on your battery.
2:04 pm May 13, 2012
| B. M.
| | Pittsburgh, PA | |
| Member | posts 5 |
I just got back from my first trip with my 2012 Classic 170RB and had a similar problem with rapid battery drainage. The lights went out the first and fourth nights. I also found out that these little trailers do not charge the battery when connected to the truck in fact it did not appear to draw on the truck battery at all so I turned the truck around and hooked up the jumper cables.
5:18 pm May 14, 2012
| eocamper
| Member | posts 19 |
Very interesting replies. I haven't looked into what is causing the battery drain. I found it easier to just disconnect the + cable for now. DW works Saturday, that will give me time to get out there and check it out.
6:40 pm May 14, 2012
if you have access to a clamp on ammeter, it will take some of the guess work out of equation. if you are unfamiliar with this tool, you just clamp it around the positive wire from the battery while it is connected and read the display. with everything off, i would expect less than .5 amp parasitic current draw. (co detector, and maybe a little draw from the converter) grossly more, as in 2 to 10amps or more would mean lights, antenna booster, pumps on, or a malfunctioning converter or furnace which would have to be checked one by one by clamping on to the positive wire going to them with the ammeter. (sorry if you know all this already, but for the forums sake someone may not). if there is little or no draw but the battery still dies quickly, then you may need to take the battery to an auto parts store. they can check the battery's condition. good sources to borrow an ammeter would be electricians. heat and air guys, and the sorts, along with that tool guy everyone knows. if that's you and you don't have one, i saw one on sale at sears for about $35.
2:55 pm May 15, 2012
| eocamper
| Member | posts 19 |
I got home and plugged the TT in to shorepower to charge the battery. That way when the weekend comes I can check it out. I have a digital multimeter to check current. One thing I did notice when connecting my battery is, the neg. battery was very loose. I'm thinking maybe i wasn't getting a good connection. I did have time to check the ant. booster and fridge. Both were off as well as lights, water pump, water heater and even checked if the thermostat switch was off.
6:56 pm June 4, 2012
| flygal6
| | Appleton, WI | |
| posts 80 |
I too early on in my ownership was having the same battery drain problem with the trailer while in storage. I continued reading on other forums too and have encountered the same complaints with the same list of reasons and also the same seeming to be best recommendation to fix the problem. As mentioned earlier here there is a certain amount of parasitic drag from the CO2 monitor, the converter and also if the pump is mistakenly left on or also the fridge in the battery mode. With that said I installed a simple keyed battery cut off switch (less than $15 at most auto part stores). Never had a problem since. I just turn it on when hooking up to the car, so I will get a fresh charge during transport.
Hope this helps.
11:07 am June 5, 2012
| BobB
| | Petoskey, Michigan | |
| Member | posts 16 |
My 19sb suddenly drained its battery while sitting in parking lot. I checked all circuits by pulling fuses with voltmeter. None were the cause of drain. Battery still pulling full power as if there is a hot ground short. Am taking it to dealer Friday. Service department agrees that it sounds like a short somewhere. Will post the outcome.
2012 Spree Escape E19SB, 2009 GMC Sierra 1500 extended cab, 4×4, 5.3 engine, tow package, 3.73 axle, no wdh or sway control (truck weighs a lot more than trailer and I drive slowly).
6:24 pm June 8, 2012
| BobB
| Member | posts 16 |
First cause of drain was probably me leaving a light on. Continuing problem turned out to be a defective volt meter. It continued to give out-of-the-park readings for current when dealership's meter showed very small parasitic drain from CO meter only. Glad I don't have a problem.
8:29 am June 9, 2012
| wanthony
| | CT | |
| Member | posts 9 |
Glad you found the problem. We have a 19sb too. I found it easy to turn the outside light on my mistake as the inside and outside switches are together. Then it is not easy to notice that the light is on during the daytime.
10:10 am June 9, 2012
| BobB
| Member | posts 16 |
Just so it doesn't happen again while the trailer is sitting unused, I've pulled the 20 amp fuse. It's called closing the barn door after the horses are… well, you get the idea.
