12:39 pm July 5, 2011
| lfcpa
| | Lubbock, TX | |
| Member | posts 23 |
Had our first "big" trip in the 2010 14rb. Thought I would report on the tow vehicle and mileage. Trip was about 250 miles each way with elevation gain of 4500' – Lubbock, TX to Ruidoso, NM. Had to escape the Texas heat so headed up to the cool pines of New Mexico. Got lucky and it rained the afternoon we arrived. First rain they had seen in a while. Stayed in a RV park (national forests are closed due to fire danger). Instead of 100+ degrees every day we had daytime highs in the low 80s and nightime highs in the high 50s. It was like a slice of heaven. My wife and I had the 14RB loaded lightly with empty tanks but did load the fridge, clothes in the closet (the shelving mod used by others here in the forum worked beautifully), bed made and food packed in the trailer. Tow vehicle is a 2010 Nissan Xterra (V-6) equipped with rear air shocks (load assist?). We used an antisway bar but no load equalizer hitch. With the air shocks there was no sag and being rear wheel drive, the rig handled very well. Towing speeds were kept pretty much right on 60mph and overdrive was locked out. Average towing rpms were about 1950. Rig ran cool. MIleage was exceptional I thought, getting 15.5 going up and over 16.5 coming back down. Just wanted to let anyone considering a V6 tow rig, that the Xterra does an excellent job. With a headwind I usually slow down to 55 because of wind drag but on this trip, the worst we experienced were cross winds. No significant trailer sway even when meeting or getting passed by semis. One other KZ Sportsmen in the campground but it was much larger, probably 22+ feet. We had the smallest trailer in the rv park. Didn't bother me but wife kept looking longingly at 5th wheels. I am quite happy with a small easy to maintain trailer and getting good gas mileage. Plenty of room for two.
We are the second owners of this 14RB and the water heater has gone out. Based upon troubleshooting guides I have read it appears that the control module has gone out. Anyone ever try taking one apart? I may end up just putting a new water heater in. It's not difficult but they aren't cheap, hence the possible repair on the control module. I think Suburban calls it an ECO or something like that. I doubt if it's supposed to be owner serviceable because the screws are all sealed. Any help appreciated.
Thanks, Lee
8:56 pm July 5, 2011
| mcmanawayp
| | Richland Center, WI | |
| Member | posts 37 |
Hi Lee,
My wife and I pull a 2011 14RB with a 2006 Chrysler Town and Country. The 3.8 V6 does a great job and, although the minivan is front wheel drive, there hasn't even been a hint of a problem towing. Our towing mileage is comparable to what you've experienced. We find that being the smallest trailer in the park does get us quite a bit of attention. Can't tell you how many times we've been approached at gas stations and rest areas by folks who want to ask about our "baby trailer"!
7:14 pm July 11, 2011
| Winterpegger
| | Winnipeg, Manitoba | |
| Member | posts 18 |
mcmanawayp said:
Hi Lee,
Water heater problem ?– Does the pilot light not stay on ? Is the flame of the pilot heating the thermocouple? Eco is a over heat senser in series with the thermocouple.I would try a new thermocouple first.
6:58 am July 12, 2011
| Yesaraf
mcmanawayp said:
Hi Lee,
Good Morning, read your post and have a question. I will be picking up my new 14RB today in the same vehicle, Chryslter Town and Country with a 3.8 engine. Do you feel you need a transmission cooler installed onl your van?
thanks
7:35 am July 12, 2011
Post edited 2:36 pm – July 12, 2011 by wrenchist
My '07 Grand Caravan with the 3.8 did not come with a tow package but I replicated it with everything but an engine oil cooler. I strongly recommend a plate type auxillary trans cooler as well as transmission fluid replacement more often than the factory recommends.
7:44 am July 12, 2011
| lfcpa
| | Lubbock, TX | |
| Member | posts 23 |
Winterpegger – I did put in a new thermocouple. Didn't work. Made me suspect the ECO wasn't working properly. All the diagnostics I found on the internet said replace the ECO. Well that little feller is almost as expensive as an entire water heater. I replaced the entire water heater last night. Got a new one shipped here. Took an hour or so to replace. I'll test it tonight.
After replacing the thermcouple on the old water heater and still finding no joy – the pilot still wouldn't stay lit – I checked the old thermocouple (the first one I had taken out) with a voltmeter. It was putting out about 25 millivolts (if I read the meter correctly) which should have been enough to work the magnet in the ECO. This same water heater also gushed hot water all out the pressure relief valve the one time I got the water heater to work. It looked like I geyser. I am pretty sure the thermostat in the ECO was also faulty.
I may try and send the ECO out of the old unit back to Suburban and see if they will replace it. The unit was less than a year old but I am the second owner of the 14RB so I have no idea what Suburban's response will be. Sinice I have already solved the problem by replacing the entire water heater I won't lose any sleep over the deal of Suburban won't help on the old ECO unit. If they do replace it then I'll have an extra water heater.
Yesaraf – I don't have a minivan but if I was using one to pull a 14RB I would definitely have a transmission oil cooler installed. It's like life insurance for your transmission. My Xterra has two transmission oil coolers – one in the radiator and a separate one. Both factory installed. An aftermarker transmission oil cooler isn't very expensive, especially compared to a transmission replacement. Enjoy your new 14RB and congratulations.
Lee
12:58 pm July 12, 2011
| Yesaraf
many thanks, I'll have a transmission cooler installed before any long trip
regards
