8:41 pm October 5, 2012
I spent a lot of time last winter reading everything that I could find regarding trailer aerodynamics and things that I could do to improve the overall fuel economy of our rig. My truck is not that efficient to begin with,(19 mpg. at its best) and I was sweating the great unknown of towing out west in the spring. The first thing that I considered was a wind deflector like you see on trucks towing bigger trailers. The general consensus regarding them , and for that matter anything you would mount to your tow vehicle is that they would have to be mounted within a foot or so of the trailer to do any good at all. Then even under optimal conditions the fuel savings would never add up to the cost of the units. The next thing I found was that you have to treat the trailer like it is on its own traveling beside you. A brick on wheels can never have a Lamborghini coefficient of drag however surely there was some room for improvement. I then read that improvements could be made by streamlining the undercarriage of the trailer, which the factory took care of for us with the black material under there. Rounding the surfaces like an airstream helps, but I did not buy an airstream, and would not even if I could have afforded one. There are nosecones that you can buy that promised improvement, but they too were expensive and change the look of the trailer. Then there was talk about the drag caused by air collapsing around the rear of the trailer and work done by the trucking industry and others (in my case, nasa) to improve airflow back there. We have all seen this sort of thing by now in one form or the other. That’s what you are seeing (and sometimes not seeing) on the backs of big rigs all across the country now. The most obvious are the three or four sided tapered sails attached to their backs. Less obvious are metal bars welded at odd angles on the tops and sides of the trailer. The intent of these devices are to reduce the low pressure (suction)drag by guiding the air coming around the trailer in such a way that it reduces the suction. The theories involved here are hard to follow, lots of talk about vortices and such. I found a product that claimed to be developed by nasa and bought into it. For a sum of money less than any wind deflector or nose cone I got a small box with about 30 of these plastic stick-ons (you can see them in my pictures). I am not endorsing these because I just don’t, so they remain nameless.
My experience with these have been good, however I cant for certain say they have improved fuel economy. I have gotten as good as 14.5mpg on i59 (flat and still air) to 6.9 mpg on i10 (Texas high country with "I cant open my door in this" wind) I can say they have dramatically improved the driving with the brakes on feeling that I had before, and when big truck pass (25+mph faster than me) there is very little of that pulling to than pushing away sway (or vise versa) that I had before. I have driven at least 5k miles since installing these. I have been sway less except for one stretch of highway between page az. And flagstaff where we had a crosswind that tried to push us over a couple of times. That made it worth it to me
5:35 pm October 7, 2012
Interestingly I just pulled in tonight from a trip up north, and it was dark and raining on the final leg of the ride home. Usually dark and rain combine for a miserable driving experience, but this particular time it was anything but. The final leg of my journey involved about 20 miles of secondary roads, with speeds typically between 35 & 50mph. Just about the whole way I had somebody close enough behind me to illuminate the area around and behind the trailer. This illumination, combined with the water on the road, served to provide me with a real-world wind tunnel test where I could easily see the air flow patterns around the truck and trailer. It was every interesting.
There were two distinct patterns constantly on display. The first was the wake from the truck, and we've all seen typical examples of such a thing when traveling with others on the interstate. The second was the wake being produced by the front of the trailer. That thing is blowing a huge hole in the wind, and the wake extends way out to the sides of the trailer before arcing back in. I mean way out, like in a several feet out to each side of the unit. Granted most of what I could see was fairly low, but it was a very graphic representation of the air movement around the unit.
I bought this trailer for its classic looks and styling, but if I really wanted the improve my mileage experience I think an Airstream would be the answer. Than rounded profile has to make a difference.
8:36 pm October 7, 2012
Post edited 3:57 am – October 8, 2012 by ron_sue
yea, i looked out a window at the freeway on rainy days watching trucks and sometimes travel trailers roll by watching their wake. (boss and customers are glad i got over that) most of the commercial trucks that i saw had some sort of treatment on the cabs, but all of them seemed to suck water up off the road behind them and caused general misty conditions behind them. i also watched one day as a semi passed one of those sign bearing children of the corn on the side of the road. when the truck passed, it pulled the domino's (or whatever) sign out of his hand and it went down the road with the truck. ( the suction drag i went after). evidently, the air rushing around comes back together right behind the trailer creating a small tornado. the devices i mentioned cause the currents (that you saw) going around the trailer come back together further back reducing the suction effect. (they want the air flow to look like an airplane wing)
anyway, when i do the math all this is really not gaining much. for my truck empty, traveling 1000 miles the best i can hope for is using around 52 gallons of gasoline. under most conditions with the trailer 80 gallons. i have a 21 gallon tank so that's just over a tanks worth of savings potential at best, four vs. three. (and that would be impossible just from the weight addition alone). we rarely venture more than 400 miles or so from home,( you are about a thousand miles from here, that radius gets me most of the country) so i cant get crazy with modifications. the tabs only hinted at a 4% increase ( .5 mpg maybe) but i thought "who knows". they do seem to help with the truck induced sway (at least in my mind) and its a conversation starter for people who have looked out a window at a freeway, or watched their own wake in the rain.
most of the time, we can go out for a week, eat our own gourmet cooking, see and do things that most only dream of, then collapse in our own bed every night for the cost of one or two nights at the Ham***on. so as the old song says "that's close enough to perfect for me"
