After years of pulling popup campers we got a 2010 14rb. Got it last week (used) and took it on the first trip this past weekend. I had read about how bad the gas mileage was so I was prepared for bad results. What I got wasn't all that bad. Tow vehicle is a 2010 Xterra. Pulled a 2010 14RB. Used antisway but no load equalizer. Have Firestone air bags assisting the back shocks of the Xterra. We had a tail wind of 30+ going and a head wind coming back of 20+. Cross winds and trucks passing were no problem. I could definitely feel the trailer and the wind resistance but had no control problems. Speed – I towed with the OD off limiting my top gear to 4th. The State park was about a hundred miles away. I towed 50-55 and often 60 but mostly 50-55. I tried to keep the speedometer about 55 but with a strong headwind or even crosswind the Xterra seemed happier sometimes at 52. The roads were lightly traveled and we were in no hurry. Gas mileage with the tailwind was just a bit over 16mpg and returning into the 20mph headwind we got just a bit over 14. I was very surprised. The terrian was flat to rolling. The 14RB was loaded lightly with camping gear but the tanks were empty.
Hope the take the rig to Colorado or NM mountains this summer. I think it will do fine if I don't get in a hurry. I will load the trailer lightly. I do think a v8 truck would be better but the Xterra will be our our only tow vehicle for the future until it's paid for.
In the introduction thread I had mentioned that the trailer springs squeaked a lot. I lubed them (mainly the spring brackets) with dupont spray teflon dry wax spray. It helped some but I think I need to lube them several more times before I can say it works well.
We did have a problem with the hot water heater. It lit just fine and the water heated ok but after about 45 mintues the water started gushing out of the water pressure relief valve near the top of the water heater. Not dripping, it was gushing. I think either it is a defective pressure relief valve or the thermostat that controls water temperature is defective. All ideas are welcomed. Anyone had a similar problem?
5000 btu a/c did just fine in mid 90s heat. Not freezing cold in the trailer but comfortably cool.
Very please with the trailer overall.
Lee
