12:42 pm August 25, 2011
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
Post edited 11:12 pm – August 25, 2011 by Eugene
So I had a fabulous initial outing in my new 14RB, which I'm lugging around with a four-banger 2007 Subaru Forester 5-speed MT. I know that's pushing the envelope for what a Forester can tow, but I pulled my 14RB up grades through the Coast Range just fine, and cruised on I-5 at 60 mph in 5th gear. However, the overall weight is less an issue than the trailer's astonishing tongue weight. I haven't actually weighed my trailer's tongue, but I've seen posts on the forum showing weights well north of 300 pounds, and I believe them now. My trim isn't optimal. The tongue is depressing (initially unintentional pun) my rear suspension several inches off level.
There are no affordable (for me) suspension enhancements for a 2007 Forester. Four-wheel independent struts rule out aftermarket airbags. And there are no bolt-on Class III hitches for a 2007 Forester that would allow me to use a weight-distribution hitch. So I'm stuck with my Class II hitch and stock suspension. Which means I need to employ strategies for reducing tongue weight that take into account I've still got to have a battery and full 20# propane tank riding on the tongue.
I'd appreciate any advice/suggestions/consolation anyone has to offer.
Thanks.
7:06 pm August 25, 2011
Post edited 2:34 pm – August 26, 2011 by wrenchist
Placing trailered cargo behind the axle will reduce the tongue weight (the further back the more affect), just don't have less than 10% of the total weight on the tongue. If the water tank is ahead of the axle on your model don't fill it until you arrive at the campground if possible.
8:21 am August 26, 2011
| DougB
| | Charlotte, NC | |
I have a #350 lb tongue weight limit so this is a constant problem for me with my 16BH. You can find the weight us a bathroom scale with the method at this link:
http://www.curtmfg.com/index.c…..eceid=1347
Note that you multiply scale reading by 3 instead of 2. Mine can be north of #400. But on the 14BH I believe the axle is more centered than the 16BH so it probably is not as bad.
I don't travel with the propane tank on the tongue. I have found it fits perfectly in a milk crate and will snugly on the floor between the door and toilet. Of course you can't run the refrigerator during travel. On the 16bh the refrigerator is forward of the axle so I use a cooler in the tub for food anyway.
That, no water in the tank, and storing anything else behind the axle gets me to around #300 which is still more than 10%. I also have air spring helpers but sounds like it's not an option for you.
10:18 am August 26, 2011
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
Post edited 5:20 pm – August 26, 2011 by Eugene
Good and helpful suggestions. Thanks, all. Unless I absolutely can't avoid it, I'm hoping not to have to move the tank because I want to be able to run my refrigerator on propane while traveling. I have begun to dream up packing schemes that use a lot of the bathroom. Don't know how much I might be exacerbating potential sway by moving so much weight behind the axle, so I guess it will be a trial and error process. Naturally, I'll run with empty holding tanks. That's best for optimal gas mileage anyway. One advantage to my wimpy tow vehicle is that on my first outing I got 18 mpg. Of course, if I blow up my tires or rear suspension with crazy tongue weight, the gas savings will sort of lose their magic. But I'm going to make this Forester work until it doesn't. Next up is a cheapo fix recommended by some folks on the Forester towing forum: rubber coil spring boosters that provide 1 1/2 inches of rear lift. The downside is you've got to take them out as soon as you unhitch or your car will ride like a stagecoach.
7:03 pm August 26, 2011
| kenigg
| | Michigan | |
| Member | posts 4 |
I use spring rubbers similar to these
http://www.amazon.com/Superior…..75-7627911
I needed two in each rear spring on my Freestlye, but only one in each spring on my Flex. These are packaged as "front spring coil boosters", but they are just the right size in the rear. They actually are barely compressed before I hook up the 16RBT (about 350lb tounge loaded). This seems to firm things up just about where I want it. I do leave them in and don't notice any difference unloaded. My non-towing ride height went up 1/8 inch, but with the trailer hooked up, my ride height went up just over 1 inch. Mission accomplished.
I do not recommend the full, "doughnut" rubbers, that would be pretty harsh
2011 16RBT towed by Ford Freestyle |
9:16 pm August 26, 2011
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
Thanks for weighing in. It's reassuring to know someone in the Sportsmen Classic family is using these boosters. Those look just like the ones I bought today at AutoZone. Maybe a tad smaller. How did you position yours on the rear springs? I've seen different recommendations ranging from 45 degrees to 180 degrees apart. Some users have complained that they fall out when you unhitch your trailer and do something that extends the springs, like hit a pothole or speed bump. Have yours stayed put?
8:43 am August 27, 2011
Post edited 4:37 pm – August 27, 2011 by Mike Magee
People in Europe routinely run their trailers at about 5% tongue-to-total weight ratio. I've never been sure where the 10% rule of thumb came from here in North America… perhaps just overkill toward safety, back in the day when all the cars and trucks had RWD and ladder frames, and maybe higher tongue weights were less of a problem. I don't think you should have a sway problem with a trailer as short as the 14RB as long as you have 150 lbs or so on the tongue. That gives you lots of room for back-end loading.
If a person had negative tongue weight (heavier in rear than in front), even a super short and lightweight trailer can sway dangerously. I know because in my younger days I misloaded a 4×8 utility trailer like that, and I scared the *&#^%* out of myself.
9:20 am August 28, 2011
| kenigg
| | Michigan | |
| Member | posts 4 |
I actually got mine at Autozone as well. I was unable to find a picture of the product on Autozones website, so I used that Amazon link. All springs are different, These just happen to fit mine perfectly. With the car jacked up and wheels hanging free there was just enough room to slide them in from the bottom. Installed on the Freestyle easily, but I had to lube them with silicone in order to work them up the springs on the Flex. These will not fall out of my vehicles. If you suspect your might, I suggest drilling through the rubbers close to where they touch the springs and looping a tie-wrap through and around the spring. On the vehicle that I used 2 per spring I have them 180 degrees apart, about midway up the spring. I figure each rubber is good for adding 100 lbs per inch of compression.
9:52 am November 11, 2011
| smokedummy
| Member | posts 8 |
Another thing to do is to move weight out of, or at least forward in, the tow vehicle. I removed a seat from my van and slid the other all the way forward. I also moved all tool boxes etc forward to just behind the front seats.
4:35 pm November 12, 2011
| Mike & Diana
Rather then mess with your TVsuspension and affect the comfort of the original design of your suspicion when driving when not towing, I'd reco the E2 sway control with weight distribution hitch. http://WWW.E2HITCH.COM. For around $200.00 installed, I'll guarantee a more controlled nd level setup. I love mine. Used it on a Trailblazer SUV and a F150. With appropriate installation, both were level!
6:25 pm November 12, 2011
$200 installed! Where? Cheapest price I've seen for the unit was $261 and that was just for the hitch, no installation. But even so that is a pretty low price to pay for weight distribution with sway control.
However, Jim, maybe you should check first with Subaru to see if WD hitches are considered ok with the Subaru "frame" (unibody, really). The other thing is, the weight of the hitch itself adds to the overall weight on your back end. Yes, the hitch will distribute that weight more evenly between all axles. But you would still be overloaded on tongue weight… it still will stress the suspension and the unibody, and don't forget what you are doing to the receiver attachment points. I read a post recently made by a VW Jetta owner who was overloading his car like that and he'd discovered that it was ripping the sheet metal up where the hitch bolted on.
Another approach would be to weld a little more support on for the rear bumper, attach a platform and mount a generator on it. Your LP tank will run things for a couple weeks even if only half full. Travel with an empty fresh water tank (and empty hot water heater too). Add a container or two of water in the tub, maybe.
7:35 am November 13, 2011
| Mike & Diana
Guess my dealer gave me a good deal then. Go figure. Even at $260.00, it's the way to go, and an easy, self – install. If your vehicle can't use this type of hitch then I might be concerned that from a safety perspective, you shouldn't be using that vehical to tow this TT at all. If I have to worry about where I needs to specifically place a couple of hundred pounds of weight, then I've got to question the overall safety.
8:51 pm November 15, 2011
| Eugene
| | Eugene, Ore. | |
| Member | posts 29 |
You're absolutely correct, Mike. There are no weight distribution hitch options for a Subaru Forester. I called the experts at eTrailer (great customer service, by the way, highly recommended) and they confirmed that the Subie won't accept WD hitch systems. But I installed the rear coil spring boosters, the biggest ones (2 inches of lift), and they did the trick. Like kenigg said, there was no problem leaving them in after the trailer was unhitched. The debate about what is and isn't safe for a Forester to tow has a long and glorious history on the Internet, and I have nothing to add to it. But I have been able to affect the tongue weight appreciably by scrupulously loading the trailer and the Forester and adding the coil spring boosters. My towing trim is dead level now, and I tow through the Cascade and Coast ranges way better than I would have expected with a four-banger hauling 2,300+ pounds uphill. Foresters rock.
9:10 pm November 15, 2011
It is my understanding that an equalizing hitch lessens the downward force on the hitch when it transfers the weight to the front of the vehicle. My receiver is rated at 350 lbs without an equalizer hitch and 400 lbs with. Perhaps you can't use an equalizer hitch because there isn't a 2″ receiver available for a Forester.
12:40 pm January 3, 2012
| rajdude
| Member | posts 15 |
Post edited 7:41 pm – January 3, 2012 by rajdude
wrenchist said:It is my understanding that an equalizing hitch lessens the downward force on the hitch when it transfers the weight to the front of the vehicle. My receiver is rated at 350 lbs without an equalizer hitch and 400 lbs with. Perhaps you can't use an equalizer hitch because there isn't a 2″ receiver available for a Forester.
I am in exactly the same boat as Eugene. The hitch for my vehicle won’t take a WD system.
I talked to the manufacture about it…they say that a WD hitch applies a twisting force to the chassis of the TV. That is how it tries to put more load towards the front of the vehicle instead of putting all the downward force on the rear end mounted hitch. Some vehicles [like mine] don’t have hitch mounts strong enough to withstand these twisting loads. However, they say my vehicle will tow loads all the way up to the 3500 limit fine without a WD system.
I suspect that Eugene’s Forrester has the same limitation.
1:11 pm January 3, 2012
| rajdude
| Member | posts 15 |
Oh wow! So your 16BH ‘s tongue weighs over 400lbs when the manufacture says it should weigh 262 lbs!
I do understand 262 is dry. Add a 40 lb full propane tank and a 60 lb battery and it should cross 362 lbs but you say over 400! That gets me really worried about my [future] 19BH’s tongue weight…. specified at 286 lbs.
DougB said:I have a #350 lb tongue weight limit so this is a constant problem for me with my 16BH. ………. Mine can be north of #400. But on the 14BH I believe the axle is more centered than the 16BH so it probably is not as bad.
1:07 pm January 4, 2012
| DougB
| | Charlotte, NC | |
Yeah, I was unpleasently supprised. Of course the fine print says "Your trailer weight will vary according to optional equipment". So in my case I suppose the advertised weight does not include the optional front window, A/C, etc. that sit in front of the axle.
