7:37 pm April 24, 2011
| flygal6
| | Appleton, WI | |
| posts 80 |
For all you folks out there who use a sway bar, does anyone have any suggestions or tips on the intial set up for first time use? How did you figure out just the right amount of tightness for your set up? Any guidance would be greatly appreciated.
8:14 pm April 24, 2011
i was told that you start with it loose, then use just two fingers pointing straight out to turn the lever till you cant turn it that way anymore. then using your whole hand, turn it another half turn. not the most percise adjustment, but it should get you in the ballpark.
6:42 pm May 5, 2011
| flygal6
| | Appleton, WI | |
| posts 80 |
thanks for the reply. Had an opportunity to ask the same thing at my RV dealer and basically used the 2 finger tight method as well, specifically so as not to overtighten too much.
